yamahaty250xox Posted August 1, 2008 Report Share Posted August 1, 2008 hi all i have purchaced a yamaha style kill swich to replace the origanal piece of s*** that is on the bike. my question is do you guys blank off the light wires (mines not fitted) and cut and conect the new kill swich in front of the block connector, or do you need to wire it in further? any sugestions welcome Max Quote Link to comment Share on other sites More sharing options...
chewy Posted August 2, 2008 Report Share Posted August 2, 2008 Dont know answer to this but have to agree with you in hope that Beta read these forums and do something about it.. One of the reasons I bought Beta was because all switches etc looked to be tidy (we keep light etc on for scrutineering in Europe) Quote Link to comment Share on other sites More sharing options...
nzralphy Posted August 2, 2008 Report Share Posted August 2, 2008 Right this is tough to explain especially with the bike in the barn. Your hand book has a wiring diagram that helps. Unplug and remove the lights from the bike - all junk/heavy/unreliable gear anyway. Now you have two loose yellow wires - unplugged from stuff you removed - plug them in together. Half done now. The kill switch essentially electrically-shorts the ignition to an earth on the frame. So...... Crimp a 5 or 6mm bolt-through-terminal connector to one wire of the kill switch. Bolt this to where the coil is mounted/earthed on your frame. Next......Crimp on a spade connector to the other wire and plug this into the Black/white wire coming out of the black box (there will be a wire with a plug on it). Done. Ralphy Quote Link to comment Share on other sites More sharing options...
