fuma Posted September 29, 2008 Report Share Posted September 29, 2008 (edited) I recently discovered that the case on my 07 Beta had corroded just below the water pump impeller in such a way that the o-ring doesn't seal tightly. The bike has limited time on it (about 25 hrs) and was purchased as a leftover last Sept. It had the factory coolant in it so it was not a matter of using the wrong product. I think the castings for the cases are sensitive to corrosion and changing the coolant is required more frequently. Ron at Beta USA stands behind his bikes and is getting me a replacement case in Aluminum. He recommends changing the coolant along with transmission oil with the magnesium cases. About every 90 days. I have engine ice in my garage and will be using this coolant. Changing the coolant every 90 days sounds like good preventative maintenance especially since the bike only holds about 500cc. Edited September 30, 2008 by fuma Quote Link to comment Share on other sites More sharing options...
