garyrepsol Posted August 5, 2008 Report Share Posted August 5, 2008 (edited) Can anyone tell me how to remove the rubber damper bushes from the rear wheel, they seem to be in blind holes. Edited August 5, 2008 by garyrepsol Quote Link to comment Share on other sites More sharing options...
max1956bikes Posted August 5, 2008 Report Share Posted August 5, 2008 i did a tl125 years ago they put up a good fight.i burnt out rubber with blow lamp then collasped the outer bush with a centre punch. Quote Link to comment Share on other sites More sharing options...
hondanut Posted August 5, 2008 Report Share Posted August 5, 2008 i have several bike with these bushes and this is how i do it. use a holesaw almost the same diameter as the rubber and drill out as much rubber as you can, then using a dremmel or simmilar grind away at the outer sleve untill it is almost through, then collapse it with a small punch or screwdriver. i also turned down some steeel to use as a driver to get the new ones in, but dont push them in too far as you will want a good tight fit on the sprocket. note: some after market sprockets are a bit thinner than the original ones and unless you use some wahsers will move about quite a bit. i hope that helps. Quote Link to comment Share on other sites More sharing options...
mattylad Posted August 11, 2008 Report Share Posted August 11, 2008 There are a few tools for just this job on ebay Quote Link to comment Share on other sites More sharing options...
