Tlr200 Sprocket Damper Bush Removal
garyrepsol
i have several bike with these bushes and this is how i do it.
use a holesaw almost the same diameter as the rubber and drill out as much rubber as you can, then using a dremmel or simmilar grind away at the outer sleve untill it is almost through, then collapse it with a small punch or screwdriver.
i also turned down some steeel to use as a driver to get the new ones in, but dont push them in too far as you will want a good tight fit on the sprocket.
note: some after market sprockets are a bit thinner than the original ones and unless you use some wahsers will move about quite a bit.
i hope that helps.
