Right Boot Rubbing Back Brake
razor
  razor said:
just got a new pair of boots, but noticed that thay are wearing, and it looks like they are catching on the brake,
any sugestions,
is this a beta if so put a domed head allan bolt where the cleaves pin is
sorry, yes 2008 rev3
i think its the clip that holds the push rod, i think i have seen a gaurd of some sort? im just trying to find out
just found this
http://www.trialcast.co.uk/bbb.htm
looks like its the 08 one........... anyone tried it?
Edited by razor
Have one of the trialcast protectors fitted to my 08 rev3. It was fitted to my 07 also. Fits well in minutes and seems to reduce the rapid wear on the boots. Make sure you use loctite on the bolt though as it comes loose easily if you dont.
i wish that i had seen that last week. i must have dislodged my clip and the rear brake rod fell out. i discovered this at the bottom of a very slippy bank when i parked my bike in the shrubbery ! much to the amusement of the on-looking que waiting for the section. :D
