firstgear Posted August 8, 2008 Report Share Posted August 8, 2008 Is anybody aware of a bearing/seal kit for the rear suspension on a 07 Sherco 290? I was recently show a kit that All Balls sells for the Gas Gas and was wondering if a kit like that exist for the Sherco? All Balls does not list a kit for the Sherco on there web site. If no kit then does anybody have the numbers for the bearings/seals needed? They seem to wear fast so it must be a common repair. Numbers listed on Sherco parts diagram seem to be difficult to find. HK 16162RS HK 14162RS HK 16202RS HK 20X20X2RS (SWINGARM) Quote Link to comment Share on other sites More sharing options...
dabomb Posted August 8, 2008 Report Share Posted August 8, 2008 (edited) http://www.splatshop.co.uk/sherco-sherco-s...-1442_1454.htmltry this Edited August 8, 2008 by dabomb Quote Link to comment Share on other sites More sharing options...
chris morris Posted August 8, 2008 Report Share Posted August 8, 2008 Check the sizes here Quote Link to comment Share on other sites More sharing options...
postmanpat Posted August 8, 2008 Report Share Posted August 8, 2008 Is anybody aware of a bearing/seal kit for the rear suspension on a 07 Sherco 290?I was recently show a kit that All Balls sells for the Gas Gas and was wondering if a kit like that exist for the Sherco? All Balls does not list a kit for the Sherco on there web site. If no kit then does anybody have the numbers for the bearings/seals needed? They seem to wear fast so it must be a common repair. Numbers listed on Sherco parts diagram seem to be difficult to find. HK 16162RS HK 14162RS HK 16202RS HK 20X20X2RS (SWINGARM) Hi,these numbers are all std refs,go straight to a bearing dealer,they'll prob be in stock,and a lot cheaper than a Sherco dealer,they will also do your seals if you take an old one with you,chences are they will be a "G" type seal Quote Link to comment Share on other sites More sharing options...
firstgear Posted August 8, 2008 Author Report Share Posted August 8, 2008 Thanks for the links. I can take it from here! Quote Link to comment Share on other sites More sharing options...
copemech Posted August 9, 2008 Report Share Posted August 9, 2008 If your bearings are gone the bushings are too, most likely, and you will only get them from Sherco unles you make them yourself. I suggest you support your dealer or importer, doubt you will save much, other than a relationship! Quote Link to comment Share on other sites More sharing options...
neo Posted August 9, 2008 Report Share Posted August 9, 2008 Check the sizes here Which number works out best for the Swingarm?? Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
bikespace Posted August 9, 2008 Report Share Posted August 9, 2008 Here's my repair list from last time, so if I understood your question, then you're after HK 2020 2 RS C169 HK 1416 2 RS Dogbone Large Bearing C168 HK 1616 2 RS Dogbone Small Bearing C151 HK 2020 2 RS Swing Arm Spindle Bearing C167 HK 1620 2 RS Swing Arm Pivot Bearing R217 Rear shock upper bushing repair kit C170 Link Spacer Front Dog Bone C171 Link Spacer Rear Dog bone C157 Rear Suspension Delta Link C175 Hex Head Screw (x2) Front Dog Bone M305 8mm Nylock nut (x2) Front Dog Bone C172 Pin 10 x 120 Rear Dog Bone bolt (x1) M304 10mm Nylock nut (x1) Rear Dog Bone C174 Pin 10 x 72 Swing arm pivot bolt C303 Front exhaust to backbox fitting rubber M259 Screw CHC 10 x 50 Top Suspension bolt C173 Pin 10 x 42 Lower suspension Bolt Quote Link to comment Share on other sites More sharing options...
neo Posted August 10, 2008 Report Share Posted August 10, 2008 Thanks bikespace Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
firstgear Posted August 11, 2008 Author Report Share Posted August 11, 2008 Copemech I totally understand about supporting your local dealer! I am a local dealer, just not for Sherco's. I am trying to help a fellow rider out and get his bike ready for the MN. Nationals. I buy all my bearings from a bearing supplier, it allows me to offer my customer a product at a fair price and I can actually make more money on it. Everyone is happy. I could buy wheel bearings from my importer at $40 ea then I have to mark it up from there. I buy direct from a local bearing distributer at $4 ea. Yes we are talking the same quality bearing. I can then mark the bearing up to say $12 and make more money and save my customer big bucks. In order for us small local dealers to make any type of profit we have to be smart and save where we can. I spend allot of time doing research on where to get the best parts for the best price both for myself and the end user the customer. Thank You for you comments. Quote Link to comment Share on other sites More sharing options...
postmanpat Posted August 11, 2008 Report Share Posted August 11, 2008 CopemechI totally understand about supporting your local dealer! I am a local dealer, just not for Sherco's. I am trying to help a fellow rider out and get his bike ready for the MN. Nationals. I buy all my bearings from a bearing supplier, it allows me to offer my customer a product at a fair price and I can actually make more money on it. Everyone is happy. I could buy wheel bearings from my importer at $40 ea then I have to mark it up from there. I buy direct from a local bearing distributer at $4 ea. Yes we are talking the same quality bearing. I can then mark the bearing up to say $12 and make more money and save my customer big bucks. In order for us small local dealers to make any type of profit we have to be smart and save where we can. I spend allot of time doing research on where to get the best parts for the best price both for myself and the end user the customer. Thank You for you comments. I agree you need to suport your dealer,but in the UK,we get so used to being ripped off by dealers,you've got to save money somewhere,so why not save on the non tied parts? They've got you over a barrel for most bits! Quote Link to comment Share on other sites More sharing options...
zippy Posted August 11, 2008 Report Share Posted August 11, 2008 firstgear Posted Today, 09:45 AM Copemech I totally understand about supporting your local dealer! I am a local dealer, just not for Sherco's. AH Yes, He is a dealer, the GREAT AND MIGHTY PARTS SUPPLIER TO TRIALS GODS!! Quote Link to comment Share on other sites More sharing options...
copemech Posted August 11, 2008 Report Share Posted August 11, 2008 God I should have thought of that! We'll buy um cheap and sell them to Zippy! Quote Link to comment Share on other sites More sharing options...
firstgear Posted August 12, 2008 Author Report Share Posted August 12, 2008 God I should have thought of that! We'll buy um cheap and sell them to Zippy! Yeah except for the fact that after Zippy tells me the wife won't let him spend any money and the kids are hungry and even though his bearings are seized he really doesn't need them as he rides away with his front tire skidding and his shorts flapping in the wind (I assume cause he can't afford pants?) I will end up chasing after him and selling the $4 bearing to him for $3.75 Quote Link to comment Share on other sites More sharing options...
zippy Posted August 12, 2008 Report Share Posted August 12, 2008 firstgear Posted Today, 07:19 AM God I should have thought of that! We'll buy um cheap and sell them to Zippy! Yeah except for the fact that after Zippy tells me the wife won't let him spend any money and the kids are hungry and even though his bearings are seized he really doesn't need them as he rides away with his front tire skidding and his shorts flapping in the wind (I assume cause he can't afford pants?) I will end up chasing after him and selling the $4 bearing to him for $3.75 Yeah First gear is just that great of a guy. Are you suggesting that if my bike was in tip top shape I would ride better? Quote Link to comment Share on other sites More sharing options...
