jeepster Posted August 9, 2008 Report Share Posted August 9, 2008 Has anybody had a problem with the cooling system pressurising on this model? if so what was the cause, im guessing a corrosion or a crack. I have removed the cylinder head with no signs of anything untoward. I ve got a feeling its the cranckcase as there are little or no exhaust fumes escaping from the radiator. please help this newbie many thanks Quote Link to comment Share on other sites More sharing options...
jse Posted August 9, 2008 Report Share Posted August 9, 2008 Has anybody had a problem with the cooling system pressurising on this model? if so what was the cause, im guessing a corrosion or a crack. I have removed the cylinder head with no signs of anything untoward. I ve got a feeling its the cranckcase as there are little or no exhaust fumes escaping from the radiator.please help this newbie many thanks Jeepster, What exactly are the symptoms and under what conditions? The cooling systems are designed to run pressurized, in part to prevent cavitation/air bubbles and for every one PSI of pressure, the boiling point of the coolant is raised approximately 2 degrees. Jon Quote Link to comment Share on other sites More sharing options...
jeepster Posted August 12, 2008 Author Report Share Posted August 12, 2008 when the engine is running the pressure cap keeps purging, so over the normal running pressure Quote Link to comment Share on other sites More sharing options...
