monkeydog Posted August 11, 2008 Report Share Posted August 11, 2008 Hi, does anyone have a water pump seal replacement guide or an exploded view of Beta Techno 250 99 model please ? Thanks in advance MD Quote Link to comment Share on other sites More sharing options...
jpope5 Posted August 11, 2008 Report Share Posted August 11, 2008 Friend of mine possibly has an issue with this also, can you tell me how you got on and if there is any advice for him. Many thanks mr.jpope@talktalk.com Quote Link to comment Share on other sites More sharing options...
monkeydog Posted August 12, 2008 Author Report Share Posted August 12, 2008 was pretty straight forward, had to remove gear selector and kickstart, then remove the clutch casing and gear cover. removed the plastic waterpump gear and removed and inspected the pump shaft. Replaced the worn seal with a new one, then reversed the procedure. Obviously you need to have drained the gear oil and coolant before you start. Hope this helps Quote Link to comment Share on other sites More sharing options...
