tombo46 Posted August 12, 2008 Report Share Posted August 12, 2008 Need a couple of bits of welding doing to my 08 300... The Exhaust mount has snapped on the exhaust where it bolts onto the top bolt of the rear brake master cylinder, what material is that part of the exhaust made out of so that I know where to take it to be welded? I also have had part of the frame snap off, Its the front right bracket that the airbox bolts onto, its snapped at the closest point to the frame, what material is the frame made from and what do I need to look out for when getting it welded? Im worried about electrics etc getting fried... All the best Tom Quote Link to comment Share on other sites More sharing options...
gii Posted August 12, 2008 Report Share Posted August 12, 2008 Check it with a magnet. If it's silver and magnetic it's a type of steel, if it's silver and not magnetic it's probably an aluminium alloy If it's gold painted, it may be a magnesium alloy I'm well aware of exceptions to the above but for the bits you are talking about the magnet test should do - there's rarely much Duplex stainless or Monel in a trials bike. When you come to re-welding brackets to the frame, be aware that it's pretty thin and is Chrome moly, keep the haz as small as you can. Quote Link to comment Share on other sites More sharing options...
tombo46 Posted August 12, 2008 Author Report Share Posted August 12, 2008 Cheers =] Tom Quote Link to comment Share on other sites More sharing options...
johnkennedy Posted August 12, 2008 Report Share Posted August 12, 2008 its very worrying that a bike that new needs welds to the frame and exhaust, if you didnt drop it from a massive step i would try it on warranty. even if it is passed its waranty time i would contact the importers, i done this and got a new frame from sherco, eventhough it was months past its warranty. you wouldnt say no to a brand new shiny frame now would you Quote Link to comment Share on other sites More sharing options...
tombo46 Posted August 12, 2008 Author Report Share Posted August 12, 2008 The problem is that I do drop it off big steps, in all fairness the bike gets alot of hammer, I wouldnt say its done badly. I recently had the master cylinder off to bleed the rear brake and may have over tightened it onto the exhaust because its only since then that it has broken. for the sake of a few quid I may aswell just get it welded, the parts that have broken arent major and wont stop me riding the bike. Ill keep it in mind though if anything more serious does happen. Cheers =] Tom Quote Link to comment Share on other sites More sharing options...
NAD1 Posted August 13, 2008 Report Share Posted August 13, 2008 The problem is that I do drop it off big steps, in all fairness the bike gets alot of hammer, I wouldnt say its done badly. I recently had the master cylinder off to bleed the rear brake and may have over tightened it onto the exhaust because its only since then that it has broken.for the sake of a few quid I may aswell just get it welded, the parts that have broken arent major and wont stop me riding the bike. Ill keep it in mind though if anything more serious does happen. Cheers =] Tom You're too nice.... Ring up dealer and whinge - A LOT! Doesn't matter what you do on it, thats what they are made for. Quote Link to comment Share on other sites More sharing options...
tombo46 Posted August 13, 2008 Author Report Share Posted August 13, 2008 Aye hehe, you know what they say, Nice guys finish last. But GasGasUK have looked after me well, really good customer service, I own a business myself so im sympathetic to being made to pay out lots for what is a relativly easy fix. Tom Quote Link to comment Share on other sites More sharing options...
mikee Posted August 16, 2008 Report Share Posted August 16, 2008 Tom, I have a 05 txt pro and have the same two bits welded back on and at the same time had all four off the air box mounts welded on the inside(gas gas only weld one side). I got a guy who is a very good welder to tig weld the parts. Hes done a top job with no worrys. Like others have said on an 08 bike talk to Gas Gas UK first, but its your bike now and if you want to ride it may be quiker to get the work done youself. mike Quote Link to comment Share on other sites More sharing options...
nzralphy Posted August 17, 2008 Report Share Posted August 17, 2008 If you plan to TIG or MIG welding the frame.... always!!!!!.....remove the electronics. It may be 20min of work but it could/will save you a heap of cash. Ralph Quote Link to comment Share on other sites More sharing options...
