Cable Maintenance
jaan
Venhill advices to use a few drops of a light 3 in 1 oil to lubricate the inner cable. What's that light 3 in 1 oil?
To nipples Venhill advices to use copper grease.
What oil and grease you use to the inner cables and nipples?
If it isn't a cable with Teflon, I use caramba. To lubricate the nipples in the lever I use conventional grease.
I think Teflon would tend to swell/expand when you use oil. I think they are developed for usage without oil.
Felix
3-IN-ONE (brand) oil is a light general purpose lubricant that has been around forever. I remember my father using it on just about everything 40 years ago. It has a pretty neat drip-spout for getting oil in tight spots without a mess or a lot of waste.
If your cables do not have a teflon liner, it is important to clean and lube them on a regular basis, preferably using a cable-luber to make the job easier and to do it right. Cables should have a light weight lubricant to keep them operating smoothly, especially in colder weather. Realistically though, if you clean them when they start getting a little sticky, almost any kind of oil will work fine.
Copper grease, a small dab of wheel bearing grease, etc. work fine for the cable nipples, and cleaning them on a regular basis is important also.
