vambo Posted August 18, 2008 Report Share Posted August 18, 2008 (edited) Hello; Been off my bike for a coupla years - ow! my knees - my back ! Was up at the Scottish and bought a new pair of Hebo's last year. Had to break them in.... Anyway, the auld Pinkie still runs but I've had a senior moment. I can't remember what the bloody mix is ! I thought 25:1 My mate reckons it's something daft like 30'ish :1 elsewhere on the 'net I've seen 50:1 mentioned. But the chainsaw runs 50:1 and I reckoned the Yam engine would need a damn sight more lubing than a chainsaw ! I don't remember ever using my chainsaw mix......So here I am. One thing is fer sure : I'm running too lean at 25:1 Whit a reek ! Mind you the pinky still runs fine on the nadgeries I was practicing on. Dunno if it would like to be opened right out in a third gear hillclimb though...... So i'm off to see if anyone has posted a mix for the TY250 - Thanks for the forums (fora?) Oh, If anyone needs it - I've got a sheet of paper with voltage readout's, timing spe'cs, reed valve clearances, CDI wiring guide etc.. Just no bloody mix ratio..... "why would I write it down, I'ts not like I'd forget....." Cheers ! Ha! I've just remembered ! it was 25ml to the litre which is erm..... 40:1 - though seems the general consensus is even that is too lean. (yes lean) (What a great forum discussing mixing ratios - I near wet myself ! ) Edited August 18, 2008 by vambo Quote Link to comment Share on other sites More sharing options...
bikespace Posted August 18, 2008 Report Share Posted August 18, 2008 You've only posted once - i like you already :-) You might have lost your marbles, but you've still got your sense of humo(u)r, and what's best - you fix your own problems so we don't have to bother lifting a finger Welcome aboard chap! Quote Link to comment Share on other sites More sharing options...
