branc Posted August 19, 2008 Report Share Posted August 19, 2008 Hi all I had been running my bike on the same oil and ratio as my 2001 gas gas txt 280 pro2 at 100-1 and I had noticed last time out on the bike that the engine was rattly and there seemed to be a lot of piston slap, bought new rings, small end etc and when I pulled it apart noticed that the back of the piston was flattened(not round as it should have been) so I put in a new piston as well. While talking to the dealer I got the bits off he asked what oil etc I was using and said I should be using semi synth instead of fully synth and at a ratio of 50-1 is this right? Quote Link to comment Share on other sites More sharing options...
gjbiker Posted August 19, 2008 Report Share Posted August 19, 2008 Have a looky here- Clicky linky This should help you decide what mix to use in the future? My Gasser manual also states 50:1 fully synth but I personally use 60:1 and have never had any problems. I'm of the old school 'better too much than too little' way of thinking but as you can see the majority run with 80:1. The choice is yours....... GJ Quote Link to comment Share on other sites More sharing options...
