Jcm Clutch Plates
barryb
Hi barry,
I am reasonably sure that the JCM motor is similar or the same as an 80's Gas Gas. That being the case you can use a clutch kit for a 2001 model 321, only the plate tangs are slightly larger than needed, so a little time is needed for filing these to size. It works well, I have done this to a 1988 model, air cooled Gas Gas.
Bye, PeterB.
