gaver19 Posted September 11, 2004 Report Share Posted September 11, 2004 I need a cylinder repair and replate. Has anyone found anywhere that does a good job with a quick turnround. Also would i have to supply a new piston, or would they supply. The bikes a fantic 307 so its not likely they would get one from normal sources. Ive tried a few places but most are quoting 4-6 weeks. I think the only place to get a piston from is Bill Pye, but to send the barrel there for him to send away is going to take longer and cost quite a bit more in postage alone. I live in south cumbria and theres no engineering firms within a 100 mile radius Quote Link to comment Share on other sites More sharing options...
its a kinda magic Posted September 11, 2004 Report Share Posted September 11, 2004 you being from south cumbria i guess you have already given birks and john wren a ring?they could pooint you in right direction. Quote Link to comment Share on other sites More sharing options...
kevin j Posted September 18, 2004 Report Share Posted September 18, 2004 I had a TY350 cylinder redone. Remove crhome, add Nikasil. Langcourts, in U.S., but their home is a UK company I think. Did right by me, although not cheap. I think it was 150 or 175 $US 5 years ago. k Quote Link to comment Share on other sites More sharing options...
hrc1 Posted September 18, 2004 Report Share Posted September 18, 2004 Plating is a specialist task - I'm sure most dealers will send barrel to Langcourt. I do & they do a good job. Plating costs Quote Link to comment Share on other sites More sharing options...
boofont Posted September 18, 2004 Report Share Posted September 18, 2004 I spoke to birks about getting a TY350 cylinder done, I think he said it would be around Quote Link to comment Share on other sites More sharing options...
jrsunt Posted September 29, 2004 Report Share Posted September 29, 2004 Yep can get your cylinder ceramic coated for Quote Link to comment Share on other sites More sharing options...
glenn Posted December 14, 2004 Report Share Posted December 14, 2004 Hi Does anybody have a contact number for langcourt's as i can't find there number in tmx. Cheers Glenn Quote Link to comment Share on other sites More sharing options...
glenn Posted January 10, 2005 Report Share Posted January 10, 2005 Hi again I'm getting my barrel back tomorrow from langcourt, and was wondering if i will have to hone it like you would after a rebore. Cheers Glenn. Quote Link to comment Share on other sites More sharing options...
kevin j Posted January 10, 2005 Report Share Posted January 10, 2005 Nope, they told me the nikasil is harder than the silcion carbide brush hone, and it just glazes the surface. Clean it with soap and hot water, check all the port deburring, and put it together. Keep the air filter clean, Nikasil should go a long time more than the original chromed bore. They did say on a rebuild, a diamond hose is good, (who has that), and a brush type silicon carbide hone would be helpful. Seems contradictory, but that's all I know. k Quote Link to comment Share on other sites More sharing options...
