Cylinder Replating
gaver19
I need a cylinder repair and replate. Has anyone found anywhere that does a good job with a quick turnround. Also would i have to supply a new piston, or would they supply. The bikes a fantic 307 so its not likely they would get one from normal sources. Ive tried a few places but most are quoting 4-6 weeks. I think the only place to get a piston from is Bill Pye, but to send the barrel there for him to send away is going to take longer and cost quite a bit more in postage alone. I live in south cumbria and theres no engineering firms within a 100 mile radius
  • 2 months later...
  • 4 weeks later...
Nope, they told me the nikasil is harder than the silcion carbide brush hone, and it just glazes the surface. Clean it with soap and hot water, check all the port deburring, and put it together.
Keep the air filter clean, Nikasil should go a long time more than the original chromed bore.
They did say on a rebuild, a diamond hose is good, (who has that), and a brush type silicon carbide hone would be helpful. Seems contradictory, but that's all I know.
k
