Removing Wiring Loom From Honda Tlr200
frontroomautos
I have a honda TLR200. I have removed the rear and front lights and battery but I want to also remove the ignition barrel & therefore the rest of the wiring loom from around the headstock so I can fit a number board where the headlight was. If I remove the wiring loom which is also earthed & connects to the coil wiring will it still run or will there be a short somewhere. Obviously CDI & coil wiring stays untouched but Can I also remove the regulator as is this only to regulate current to the lighting to stop bulbs blowing?
If anyone has done this could you advise me please, thanks.
Disconnect the ign switch first as most Jap bikes will run when you do this. You don't need the regulator either I don't think. You will also keep the kill switch.
Edited by bo drinker
