Aprilia Climber Rear Shock
nathanharold1987
Falcon can rebuild it for you. However after checking on the rebuild price, initially i modified a 303 (I think) fantic shock (roughly the correct length) to fit then eventually found a secondhand climber shock on ebay.....
With regard to the forks, I fitted a set of conventional fantic 303 forks and yokes which made a big difference over the original USD - made a spacer to fit the smaller spindle size and fitted the original front wheel.
Andy
