nathanharold1987 Posted August 27, 2008 Report Share Posted August 27, 2008 (edited) Hi. Can anyone supply me with the specification of the front forks for an Aprilia Climber 1992 280R. The forks feel quite hard, I have stripped forks down and found the internals to be a mix of parts to make it "work". An exploded diagram would be ideal with info like spring dimensions and spacer sizes etc so i can rebuild them somewhere near to the original specification. Any info greatly apprichiated. e-mail: nathanharold@blueyonder.co.uk if you can send any diagrams cheers nathan Edited August 27, 2008 by nathanharold1987 Quote Link to comment Share on other sites More sharing options...
duncanstokes256 Posted September 2, 2008 Report Share Posted September 2, 2008 let me know if you have any takers, I'm after similar info. Just stripped my front forks on my 93 Aprilia - rubber seals fell apart as I extracted the top inner leg!!! No parts anywhere so resorted to buying a set from a breakers - which in turn were larger than my top yoke. Inner parts were totally different with nothing interchangable whatsoever. Anyway sorted in the end - a couple of O rings seemed to replace the knackered seal and all working fine. So let me know if you need some spare parts, just be warned the forks seem very model specific around the 92/93 model year. Good luck Duncan Quote Link to comment Share on other sites More sharing options...
