godzilla Posted August 28, 2008 Report Share Posted August 28, 2008 i have lost all power in my rear brake, the bike was taken apart for powdercoating. while it was apart the master cylinder came off the resevoir. could anyone expleain how to bleed it? Quote Link to comment Share on other sites More sharing options...
albert Posted August 28, 2008 Report Share Posted August 28, 2008 Take the rubber pipe off the resevoir and push fluid back towards caliper. Quote Link to comment Share on other sites More sharing options...
postmanpat Posted August 28, 2008 Report Share Posted August 28, 2008 Hi,try flushing back from caliper to reservoir,use a syringe and a piece of tubing,i get my syringes from the vets,60ml cost about a quid,the tube is 6mm? poly (screenwasher pipe) from diy shop,drain the res so there is room for new fluid,last time took me 3 goes to get all the air out,but i've a mint pedal now Quote Link to comment Share on other sites More sharing options...
scorpa4banger Posted August 29, 2008 Report Share Posted August 29, 2008 Hi mate had the same problem ... your best bet is firstly checking the seals on the master cylinder .. and the banjo at both ends .. take the pots out of the caliper fill both halves with oil then put them backtogether .. then stick a syringe on the tube attached to the bottom of the reservoir and push fluid back through the bleed nipple by pushing opening closing refilling 7 or 8 times and you should get pressure back also make sure there is no holes in the low pressure hose Quote Link to comment Share on other sites More sharing options...
godzilla Posted August 29, 2008 Author Report Share Posted August 29, 2008 (edited) Thanks for the fast reply guys. its working better than ever now. I removed the pipe from the resevoir and put a smaller pipe with a srynge full of fluid down it and slid the clip back over, then opend the bleed nipple. nothing happend. so i removed the nipple which was full of crud, cleaned the crud out and started again. this worked first time! Edited August 29, 2008 by godzilla Quote Link to comment Share on other sites More sharing options...
