furse Posted September 14, 2008 Report Share Posted September 14, 2008 Can anybody help! Im in the process of rebuilding a rear kick 200, which had stood for years and had no kickstart when I got it. What keeps the kickstart shaft in place? there is an M6 thread in the casing above the shaft, should something bolt in here and clamp onto shaft? How much are the footrests lowered and moved backwards? Thanks in advance Quote Link to comment Share on other sites More sharing options...
bilc0 Posted September 14, 2008 Report Share Posted September 14, 2008 Go to this website. frankfieldfantic.co.uk Press engine diagram's and you will see there a manual for 200 this will give you an idea how the kick assembly should go in...from what i recall that hole stays empty i think,been along time since i've had my case off. Quote Link to comment Share on other sites More sharing options...
