Sherco 1.25 With A Flatslide
worldtrialchamp
Hi worldtrialchamp
My notes from past posts.....
Jetted Sherco125 - 38/125 Standard Needle
Howard Wallace
I`m running a KeiHin with 38 pilot, 110 main, JJH Needle.
The 125 + 200 have a different crankcase casting, with a shorter length where the reed block mounts.This makes it a bit tighter, and the float bowl drain hex needs a chamfer to clear the top of the gearbox , also need a hose from carb to airbox about 50 mm long. I use the radiator hose off a car with the right diameters. It`s a bit of work to fit up, but the performance gains are well worth it.
Cheers, ShercoH
45/118 apparently stock unleaded fuel.
Cheers guys, fitted the b*stard last night. Haven't got my hands on jets yet, running standard 45/125 jets, JJH needle, clip in the middle position.
Air screw half a turn out and its near right, any further out and it just bogs down when you whack the throttle open from tickover.
Hope this lot helps
Best of balance.
Neo
