Light Pink Oil?
angusgill
Don't be too hasty....are you sure its not just ATF in the gearbox rather than 'oil'?
Water ingress normally causes white emulsion in oil rather than pinkiness?
Maybe others will confirm this. Certainly check the system but I wouldn't be rushing out to buy bits unless I had made sure.
The pink colour of your "oil" is water in the ATF that is most often used, and recommended by many for the gearbox/clutch. I have changed many of the seal/shaft assemblies on the Pro bikes as this would appear to be a weak point of the otherwise good engines.
Spencer
