Cluch Looses Pessure
smurf2471
Hi i have an gasgas txt 125 02, and to add the clutch fluid we use a compressor and this tin thing (it works quite good actually) But then after about a week my clutch looses its pressure and basically becomes useless. My dad has replace the o ring's and that has not helped so could any of you guys help us out?
Thanks in advance, Smurf
Edited by smurf2471
Why use a compresser, ive always thought they work with air!
Try doing a proper bleed on it, no compressors or that nonsense!
pretty much like this
1. Turn handlebars so reservoir is level
2. Place rags anywhere you don't want brake fluid
3. Remove reservoir cover, diaphragm cover and diaphragm
4. Connect a bleed hose to the bleed valve
5. Loosen the bleed valve and pump the clutch lever
6. Stop operating the lever when no fluid flows out of the bleed valve
7. Close the bleed valve
8. Fill the reservoir
9. Install the diaphragm and reservoir cover
10. Install and tighten the cover screws
Edited by shercoman2k8
Now I see why Sherco clutches work so bad... LOL
That list is a good start, but I think it does have a major errors. Stop operating the lever fhen no FLUID flows out?
-Jan
Edited by JanDyb
I get better results by back bleeding mine, putting a syringe on the bleed nipple on the engine and forcing the oil back through to the reservoir, I do this four or five time until no bubbles come out with the oil. It can be very messy but wrapping an old towel around the bar and reservoir helps catch most of it.
It would appear that your problem is unrelated to the bleeding proceedure, i.e. "(it works quite good actually) But then after about a week my clutch looses its pressure and basically becomes useless". I'd probably put a rebuild kit in the master cylinder. Sometimes the first o-ring on the piston shaft will wear due to grit getting inside the rubber boot (I use DOT-5, which does not deteriorate the rubber) and any ingested dirt will slightly enlarge the first part of the bore (brake fluid+fine grit=grinding compound). The combination of slightly tapered bore and worn o-ring can allow air to get sucked into the M/C as the clutch is used a lot more than the brake and the throw is always longer.
Oh, I'd also check the fittings just to be sure.
Jon
Edited by JSE
