beta rev 3 Posted September 19, 2008 Report Share Posted September 19, 2008 My daughters 99 1.25 sherco needs new main bearing and possible piston due to a slapping and rumbling sound coming from engine, is there a posting on how to replace these or has any one done these job's can help me with there experience. Quote Link to comment Share on other sites More sharing options...
zippy Posted September 19, 2008 Report Share Posted September 19, 2008 (edited) Here is a list of many useful repair manuals for Shercos. http://www.sherco.com/wayne_corner.html You could scroll down and look for the one for main bearings or just click this. http://www.sherco.com/wayne/Sherco%20Engin...ly%20Manual.pdf When my Brother had his 2000 250 he printed all of these manuals off in full color and put them in plastic sleeves in a 3 ring binder. He then sold the bike a few months later. I inherited the manuals, Thanks oh wonderful Brother of mine. I did a complete teardown of my 2000 2.9, If you follow the manuals and take your time, it is not that bad of a job. I would assume the principles are the same on a 99 1.25. Just make sure you have enough work bench space to lay out all the parts of the engine. Edited September 19, 2008 by ZIPPY Quote Link to comment Share on other sites More sharing options...
blackrandomapple Posted August 18, 2010 Report Share Posted August 18, 2010 Here is a list of many useful repair manuals for Shercos.http://www.sherco.com/wayne_corner.html You could scroll down and look for the one for main bearings or just click this. http://www.sherco.com/wayne/Sherco%20Engin...ly%20Manual.pdf When my Brother had his 2000 250 he printed all of these manuals off in full color and put them in plastic sleeves in a 3 ring binder. He then sold the bike a few months later. I inherited the manuals, Thanks oh wonderful Brother of mine. I did a complete teardown of my 2000 2.9, If you follow the manuals and take your time, it is not that bad of a job. I would assume the principles are the same on a 99 1.25. Just make sure you have enough work bench space to lay out all the parts of the engine. What new parts did you buy? i.e gaskets etc Quote Link to comment Share on other sites More sharing options...
rockyrider Posted August 18, 2010 Report Share Posted August 18, 2010 Before you start the job, make sure the engine through bolts are tight to the frame, we had a bike in like that today, it rumbles like main bearings. Quote Link to comment Share on other sites More sharing options...
zippy Posted August 19, 2010 Report Share Posted August 19, 2010 What new parts did you buy? i.e gaskets etc Head O-Rings Piston rings small end bearing wrist pin circlips base gasket clutch cover gasket center gasket reed intake gasket reed valves crank bearings crank seals exhaust gasket I should have bought a new piston, but NNNOOOO I was too cheap. So there is much piston slap and rattles like crazy . And now 2 years later I am buying. Head O-rings Piston kit (piston, rings, wrist pin and circlips) Rechromed barrel small end bearing base gasket exhaust gasket Quote Link to comment Share on other sites More sharing options...
copemech Posted August 19, 2010 Report Share Posted August 19, 2010 Head O-Rings Piston rings small end bearing wrist pin circlips base gasket clutch cover gasket center gasket reed intake gasket reed valves crank bearings crank seals exhaust gasket I should have bought a new piston, but NNNOOOO I was too cheap. So there is much piston slap and rattles like crazy . And now 2 years later I am buying. Head O-rings Piston kit (piston, rings, wrist pin and circlips) Rechromed barrel small end bearing base gasket exhaust gasket Do you actually need a rechrome? Lots of times a bore can be cleaned up quite acceptably with a hone job and an oversized piston. This work is a bit specilized and the bore measured properly though. A good cyl shop can tell you! Quote Link to comment Share on other sites More sharing options...
zippy Posted August 19, 2010 Report Share Posted August 19, 2010 Do you actually need a rechrome? Lots of times a bore can be cleaned up quite acceptably with a hone job and an oversized piston. This work is a bit specilized and the bore measured properly though. A good cyl shop can tell you! Easier and less down time to just ride it until the parts show up from Dealer Dude and swap them out and send my barrel in for the core charge. Similar to what is done with a starter, ya know get a re-manufactured one and pay the core charge, and get the core charge back when you take in your bad starter. Since I will probably not get a new bike for another 10yrs the other benefit is it will be a totally new top end and when I need to replace pistons later I will be able to replace more pistons before I need a new barrel............did that make any sense there???? Quote Link to comment Share on other sites More sharing options...
ham2 Posted August 19, 2010 Report Share Posted August 19, 2010 Yup!...we speaka-da-language here Zippy. Quote Link to comment Share on other sites More sharing options...
copemech Posted August 20, 2010 Report Share Posted August 20, 2010 Easier and less down time to just ride it until the parts show up from Dealer Dude and swap them out and send my barrel in for the core charge. Similar to what is done with a starter, ya know get a re-manufactured one and pay the core charge, and get the core charge back when you take in your bad starter.Since I will probably not get a new bike for another 10yrs the other benefit is it will be a totally new top end and when I need to replace pistons later I will be able to replace more pistons before I need a new barrel............did that make any sense there???? I am sure Zipper explained all this logical quick swap stuff to the keeper of the family jewels! He He He!!! She should have asked, "Why do you need fresh chrome for the same old ass!" Quote Link to comment Share on other sites More sharing options...
zippy Posted August 20, 2010 Report Share Posted August 20, 2010 I am sure Zipper explained all this logical quick swap stuff to the keeper of the family jewels! He He He!!!She should have asked, "Why do you need fresh chrome for the same old ass!" She did ask that question, and I told her "So that your ass will be all shiny and get my attention again" I should be out of the hospital in time to ride trials in 2011. (just joking) Zippy done sold his little 250 Ninja to get $$$ for parts for the other bikes. I have been having so much fun with that little Toyota MR2 I just did not see a reason to keep the Ninja. MR2 I can drive in the cold and the rain, but due to the miracles of heaters and a roof I stay warm and dry. The MR2 is a more "practical" toy. Quote Link to comment Share on other sites More sharing options...
