hewson Posted September 21, 2008 Report Share Posted September 21, 2008 Hi everyone , i have a slight leak on my alloy tank on my bully 340 , as its just been recently painted i dont fancy getting it welded just yet .My question is are the liquid tank sealers around any good, anybody recommend a good one .....Thanks in adavnce Quote Link to comment Share on other sites More sharing options...
tony283 Posted September 21, 2008 Report Share Posted September 21, 2008 I have used KREEM on two alloy tank with great success. Tony Quote Link to comment Share on other sites More sharing options...
bothfeetdown Posted September 21, 2008 Report Share Posted September 21, 2008 (edited) I'm planning on using this from Frost, I didn't see Kreem when I was looking http://www.frost.co.uk/item_Detail.asp?pro...mp;FrostSubcat= Edited September 21, 2008 by bothfeetdown Quote Link to comment Share on other sites More sharing options...
swooshdave Posted September 21, 2008 Report Share Posted September 21, 2008 I have never heard anything positive about Kreem. I tried POR-15 in a fiberglass tank or two. That was a mistake. And that mistake was mine. It probably works ok in metal tanks. For fiberglass I will only use Caswell's epoxy. Quote Link to comment Share on other sites More sharing options...
irishjohn Posted September 22, 2008 Report Share Posted September 22, 2008 Kreem has worked very well on all the metal tanks I have used it on. It is critical to remove as much rust as possible if the tank is rusted. I would not use it on a fiberglass tank. My experience in using it on a '75 Bultaco tank was less than successful. Quote Link to comment Share on other sites More sharing options...
motovintage Posted September 24, 2008 Report Share Posted September 24, 2008 I would try to patch it from the outside, use some epoxy, jb-weld, or marine tex, if it's a small leak it wont take very much, I'm guessing it's leaking from a cracked weld, I don't recomend Kreme, it doesnt last but a few years then starts to peel. Quote Link to comment Share on other sites More sharing options...
