gassar Posted September 24, 2008 Report Share Posted September 24, 2008 does anyone know the small end bearing size for a 06 290? can they be obtained from a local bearing dealer? ta.. gassar Quote Link to comment Share on other sites More sharing options...
motofire Posted September 24, 2008 Report Share Posted September 24, 2008 Cant answer your question on size sorry...but, I get all my bearings for my bikes from a bearing dealer. They are half the price(at least) and sometimes you can get better quality bearings. Quote Link to comment Share on other sites More sharing options...
titanium Posted September 24, 2008 Report Share Posted September 24, 2008 Go to www.shercousa.com Look under the tab: service info In there you will find the parts manuals, and the bearing size is probably listed. When you say small end bearing size are you referring to the crank? Quote Link to comment Share on other sites More sharing options...
gassar Posted September 24, 2008 Author Report Share Posted September 24, 2008 Cant answer your question on size sorry...but, I get all my bearings for my bikes from a bearing dealer. They are half the price(at least) and sometimes you can get better quality bearings. that's the point without the size a bearing dealer is not much use?? Quote Link to comment Share on other sites More sharing options...
gassar Posted September 24, 2008 Author Report Share Posted September 24, 2008 Go to www.shercousa.comLook under the tab: service info In there you will find the parts manuals, and the bearing size is probably listed. When you say small end bearing size are you referring to the crank? no the bearing that connects the piston to the con rod via the gudgeon pin? Quote Link to comment Share on other sites More sharing options...
titanium Posted September 25, 2008 Report Share Posted September 25, 2008 The Sherco manual says (KBK 16x20x18) although that is for the 2007 model. The bearing is not listed in the 2006 manual. Quote Link to comment Share on other sites More sharing options...
motofire Posted September 25, 2008 Report Share Posted September 25, 2008 that's the point without the size a bearing dealer is not much use?? Werent you looking for help on 2 points? Sorry I wanst much use. Quote Link to comment Share on other sites More sharing options...
