Bearings
gassar
Cant answer your question on size sorry...but, I get all my bearings for my bikes from a bearing dealer. They are half the price(at least) and sometimes you can get better quality bearings.
that's the point without the size a bearing dealer is not much use??
Go to www.shercousa.com
Look under the tab: service info
In there you will find the parts manuals, and the bearing size is probably listed. When you say small end bearing size are you referring to the crank?
no the bearing that connects the piston to the con rod via the gudgeon pin?
