Resetting Montesa 4rt
montyboy
It would be helpfull to know what problems you are having? Reset the system!! I presume you mean the throttle body, if its a standard which it was on the 2005 model then you cannot reset it. If it is programmable then you need software maps, leads, computer and a battery...........................................
Have you tried dissconnecting the bank angle and linking cables out,red/white to brown .I think.
The only reset i know of is to open throttle fully then slow push down on the kick start let it back up and let go of throttle.
Hope this helps.
