gasgas1 Posted October 4, 2008 Report Share Posted October 4, 2008 hi i need torque settings for the cylinder barrel nuts & cylinder head bolts for a jt 250 1993 cheers Quote Link to comment Share on other sites More sharing options...
jse Posted October 4, 2008 Report Share Posted October 4, 2008 hi i need torque settings for the cylinder barrel nuts & cylinder head bolts for a jt 250 1993 cheers I'm trying to remember the capscrew size of the Jt head, but I think they go to about 12 ft lbs (16 Nm) and the cylinder base nuts to about 18 (25 Nm) ft lbs. I'm pretty sure the head capscrews use an o-ring under the washer, if so, be sure to grease them so they don't bind and tear during installation. After running for a time and cooling off, it's a good idea to re-torque them to prevent future loosening. Jon Quote Link to comment Share on other sites More sharing options...
d11kyp Posted May 7, 2011 Report Share Posted May 7, 2011 I'm trying to remember the capscrew size of the Jt head, but I think they go to about 12 ft lbs (16 Nm) and the cylinder base nuts to about 18 (25 Nm) ft lbs. I'm pretty sure the head capscrews use an o-ring under the washer, if so, be sure to grease them so they don't bind and tear during installation. After running for a time and cooling off, it's a good idea to re-torque them to prevent future loosening. Jon hi there wud these torque settins be the same for a 95 jt 250 Quote Link to comment Share on other sites More sharing options...
jse Posted May 7, 2011 Report Share Posted May 7, 2011 hi there wud these torque settins be the same for a 95 jt 250 I think so. jon Quote Link to comment Share on other sites More sharing options...
