jonnyc Posted October 5, 2008 Report Share Posted October 5, 2008 wats the 04 beta like? is it a good bike??? Quote Link to comment Share on other sites More sharing options...
the addict Posted October 5, 2008 Report Share Posted October 5, 2008 (edited) I had an 04 and yes they are a good bike, it may be prone to needing a new stator so check if its had a new one recently or at all, a replacement might cost you 100 quid. If its been rode alot you might need a shock service,someones just posted a company who does this on Ebay, check wheel bearings,forkseals colour of water in the rad and what the clutch oil looks like. Should start firstish kick, make sure it idles clean and revs out clean, any nasty rattly noises might be costly from engine and gearbox. Edited October 5, 2008 by The Addict Quote Link to comment Share on other sites More sharing options...
jonnyc Posted October 5, 2008 Author Report Share Posted October 5, 2008 ryt thanks hey!! Quote Link to comment Share on other sites More sharing options...
amcq46 Posted October 6, 2008 Report Share Posted October 6, 2008 From my history with Betas, there was one other weakness. You should also check for any water leaks or corrosion on the joint between the main clutch side cover and the water pump housing. it is know for the coolant to eat into the casting [i think it is reacting with the magnesium content, even if you use the correct coolants] from the inside and eventually undermine the o-ring seal. If there is even the slightest weep on the bottom of the waterpump it is likly this is happening, then it will need a new clutch cover casting. Other than that I was happy with my Beta when I had it. Carb didnt leak and Stator didnt fail! Quote Link to comment Share on other sites More sharing options...
