trials lad Posted September 20, 2004 Report Share Posted September 20, 2004 Hi all My boss has bought a what seems to be very original Montesa 247,its been parked in a shed for a few years and it needs a bit of TLC. so im doing a few things that need to be done to it but what I need to know about it first is what year it is so heres the frame number: 21M18677. but its painted in some very strange colours for a montesa as the tank and mud guards a bright yellow and the very large seat is blue. I dont know whather it has be resprayed these colours later in its life but it sure stands out in a crowd! . and some other info please 1. What fuel/oil ratio does it run? 2. How much gear box oil should it have and what grade? 3.Whats the spark plug gap and the points gap? Thanks in advance Danny Quote Link to comment Share on other sites More sharing options...
landrover Posted September 20, 2004 Report Share Posted September 20, 2004 GIVE JEFF BUNGAY AT MAINLY SPANISH 01425-611287 A RING, HE WILL TELL YOU EVERY THING YOU WANT TO KNOW Quote Link to comment Share on other sites More sharing options...
vintagecota Posted September 21, 2004 Report Share Posted September 21, 2004 It's likely an early '75. Use 50:1 or 2% for ample lubrication with minimal smoking. points - 0.4mm (0.016") plug - 0.5-0.6mm (0.022") gear oil - SAE 80/90 (300cc) clutch oil - 200cc ATF (automatic transmission fluid) If the seat is big it is probably a "T" (trail) model. The trials model "L" has a 1 gal. tank, the "T" has 2 gals. The "T" also has extra footpegs on the swing arm. Same bike, different tank. Good Luck! Quote Link to comment Share on other sites More sharing options...
Guest Yamaha_dude Posted September 25, 2004 Report Share Posted September 25, 2004 Hows it coming on? Quote Link to comment Share on other sites More sharing options...
trials lad Posted October 4, 2004 Author Report Share Posted October 4, 2004 Hi... Its going well, it runs like a beauty after further examination the bike is in AMAZEING condition it has hardly any chips or scraches that are normally covered over a bike of its age. The only bad things on it are the frame has been painted red and the tank yellow which looks awful so I gotta get it sand blasted and I gotta spray it black . Danny Quote Link to comment Share on other sites More sharing options...
