Bent Kickstart.best Way To Fix?
dabomb
Hi all,my kickstart on my 04 sherco is bent slightly,and its getting a pain to start because my boot keeps slipping off.Whats the best way to straighten it,can you use heat on alluminium?,I`m not sure.Can any body help?
Cheers :huh:
My experience with these is not good. You might try heating slightly with a hair drier to basically cold work it a bit. It appears to me the alloy is heat treated to attain its strength. If you heat it much, it will anneal and loose its strength, worse than before! :huh:
Wish for better news!
I have had very good success with the cast aluminium brake pedal on a Beta. Bending "work hardens" aluminium and heating followed by slow cooling softens it. The trick is to find the right temperature for softening. I believe that is what the soap trick listed above does. (burn off temperature = softening temperature) I have used an acetelene torch in the same way. You can use a very "rich" torch setting to coat the aluminium with black soot. Then use a standard setting to burn the soot off. It would then be soft and ready for bending within reason. My Beta pedal was bent into a U shape so I used two or three heating then bending steps to get it back to straight. I have also heard you can coat with black magic marker and then burn off but I have not tried that.
