steve fracy Posted September 20, 2004 Report Share Posted September 20, 2004 Just wondering if anyone out there knows the correct jetting for a 240 Fantic operating at sea level?? Any help would be great! Cheers, steve Quote Link to comment Share on other sites More sharing options...
fanticisti Posted September 21, 2004 Report Share Posted September 21, 2004 Steve ..ah yes the infamous Trial 240 Professional. Steve Saunders said it was a giant killer.. Nigel Birkett set standard time on one in the Scott... John Lampkin said 'my 240 Fantic's fanTAStic' ...anyway back to the spec sheet for the 240 with the Dellorto PHBL 25 BS Main 98 Pilot 44 Choke 60 Needle D33 2nd notch Spray Nozzle AQ 268 or 268 Carb Slide No.40 ...depending which side of the ocean you are on of course!! Quote Link to comment Share on other sites More sharing options...
grib Posted June 29, 2005 Report Share Posted June 29, 2005 Can anyone clarify which slide should be in a 240 carb? This post says 40, this french site says 50, and I have also been told 45 by someone else. My 240 has a (knackered) 50 in it and I am wondering whether it is the right one or whether I should replace it with a 40 or 45, any ideas anyone? Quote Link to comment Share on other sites More sharing options...
348mate Posted June 29, 2005 Report Share Posted June 29, 2005 Can anyone clarify which slide should be in a 240 carb? let me know where to find the slide # i will check my 240's carb tommorow. where on iom are you, i have a lot o fam/friends there. S.M. Quote Link to comment Share on other sites More sharing options...
grib Posted June 30, 2005 Report Share Posted June 30, 2005 (edited) I have already checked the price of the parts I need and it is actually more than the cost of a new carb, but I need to know which slide to order in the new carb. Thanks 348mate - the slide number is on the underside of the slide next to the needle. (BTW I live in Douglas). Edited June 30, 2005 by Grib Quote Link to comment Share on other sites More sharing options...
grib Posted June 30, 2005 Report Share Posted June 30, 2005 Thanks HondaRS but I know how to order a carb! it was the slide number I was after. Quote Link to comment Share on other sites More sharing options...
348mate Posted June 30, 2005 Report Share Posted June 30, 2005 Grib, mine has a 50. s.m. Quote Link to comment Share on other sites More sharing options...
martinm Posted June 30, 2005 Report Share Posted June 30, 2005 Steve I ran a 240 Fantic in the National twinshock championship here in the UK a few years ago and used a PHBH26BS carb from a 300. I ran it on stock 300 jetting and the performance gain was dramatic. Pretty well everyone else at the time was running the same set ups on there 240's and even Fantic eventually used the bigger carb on the 245's onwards. I know it doesn't answer the original question, but if you are replacing the complete unit, go for the 26mm instead. Cheers Martin Quote Link to comment Share on other sites More sharing options...
