pjt706 Posted October 16, 2008 Report Share Posted October 16, 2008 (edited) Could anyone tell me if a 125 pro flywheel will fit on the same year 250 pro? And yes, both bikes have the same ignition system. Edited October 16, 2008 by pjt706 Quote Link to comment Share on other sites More sharing options...
lowbrow Posted October 17, 2008 Report Share Posted October 17, 2008 I have the Hebo flywheel weight fitted to my 300 and I know this will fit a 125, however the 125 has a different female thread in the end of the crank and therefore requires a different cap screw (supplied). Other flywheel weights do not rely on the flywheel centre bolt for attachment and these should also be a universal fit, but I have no direct experience. Quote Link to comment Share on other sites More sharing options...
spenser Posted October 17, 2008 Report Share Posted October 17, 2008 I think that you will find that the tapered end of the crank is smaller on the 125/200 and therefore the flywheels are not interchangeable. I would be surprised if the 250/280/300 Hebo flywheel weight fit the 125/200 flywheel but stranger things have happened. Spencer Quote Link to comment Share on other sites More sharing options...
