the addict Posted October 16, 2008 Report Share Posted October 16, 2008 Anyone tried the "Braking" sintered pads in a trials bike on here? lots of us having a few probs with the 4rt front brake in streams so need to try other pad makes or possibly another type of disc. Thanks Just Quote Link to comment Share on other sites More sharing options...
copemech Posted October 17, 2008 Report Share Posted October 17, 2008 My impression is that discs are discs, unless you are talkind stainless, which requires a softer lining material to survive. Yet the sintered material may work well? Powdered iron on steel? May wear some disc? Price of performance in some cases, you never know! Quote Link to comment Share on other sites More sharing options...
baldilocks Posted October 17, 2008 Report Share Posted October 17, 2008 How you doing addict ? Mont disc has bigger cutaways so try fitting a Gas Gas disc instead, this worked for a mate of mine. Best pads for performance I have found are DP (try shirty) but they damaged the discs on my scorpa. Goldfren pads are a good middle of the road option. Quote Link to comment Share on other sites More sharing options...
clav3 Posted October 17, 2008 Report Share Posted October 17, 2008 (edited) I've just tried my sons non floating gas gas front disc off his 50 cc ( same hub). Every gaser I've ridden has had better brakes than both the sherco's I've owned. Brakes now are heaps stronger with no squeal. The 09 sherco looks like it has the same discs as gas gas. Edited October 17, 2008 by clav3 Quote Link to comment Share on other sites More sharing options...
the addict Posted October 17, 2008 Author Report Share Posted October 17, 2008 Thanks guys, had heard about gasser discs being better than the Monts, got a set of sintered pads here and will stick them in next week and report back. Good thanks Glenn, bit older and uglyier though but really enjoying the 4rt Quote Link to comment Share on other sites More sharing options...
the addict Posted October 18, 2008 Author Report Share Posted October 18, 2008 (edited) Me,Dad and Ralph sneaked up the dishes today for a few hours so I stuck the sintered pads in for a try. They work alot better than the Galfer ones,much stronger feel to the brake and you can lock it easy if you need to but not snatchy. Got a Trial up North tomorrow mainly streams so hope they work ok in the water - bone dry at the dishes so bloody good in the dusty stuff. Edited October 18, 2008 by The Addict Quote Link to comment Share on other sites More sharing options...
the addict Posted October 19, 2008 Author Report Share Posted October 19, 2008 Rode the John Mac today with the new pads, plenty of water about and lots of wet muddy slippy stuff in the first group. Pads were 10 times better than before, never had any front brake problems all day,almost like riding in the dry they remained that strong. Will have a look at wear on the disc tomorrow and pads but to be honest they work so well I'm not bothered if it wears a disc out every 3 months its worth it. Quote Link to comment Share on other sites More sharing options...
copemech Posted October 21, 2008 Report Share Posted October 21, 2008 I may be with you, noise problem alone on the Sherco may do it! Funny thing is the discs are from Braking! You would think the linings would work fine, where did you get them? As a sidenote, seems Sherco has changed discs on the '09, may be same as gassers, not sure? Quote Link to comment Share on other sites More sharing options...
the addict Posted October 21, 2008 Author Report Share Posted October 21, 2008 (edited) Hi Mark, how you doing, I got the pads off Ebay UK, do a search for montesa 4rt and they will be on the first page, if you want a set sending let me know via pm Edited October 21, 2008 by The Addict Quote Link to comment Share on other sites More sharing options...
surgeonrocher Posted October 21, 2008 Report Share Posted October 21, 2008 I'm not bothered if it wears a disc out every 3 months. Quote Link to comment Share on other sites More sharing options...
the addict Posted October 21, 2008 Author Report Share Posted October 21, 2008 (edited) Clarkey!!! Edited October 21, 2008 by The Addict Quote Link to comment Share on other sites More sharing options...
motovintage Posted October 21, 2008 Report Share Posted October 21, 2008 I'm using the dunlopad sintered pads on the 315R and have been very pleased with pad life, grip on the stainless disk was not as good on the rear as the and I cut a vertical grove to add grip, that worked fine, disk wear is no worry with the stainless disk, they do take a while to bed in Quote Link to comment Share on other sites More sharing options...
the addict Posted October 21, 2008 Author Report Share Posted October 21, 2008 Motovintage, not checked the pads yet for wear after the weekend but really pleased with front brake now in the wet, still using the standard 4rt disc so will keep an eye on disc wear over the next few weeks. Back brake is fine on the 4rt so no need for a change there but may when the Galfers wear out. Quote Link to comment Share on other sites More sharing options...
copemech Posted October 22, 2008 Report Share Posted October 22, 2008 Just, most of the UK companys do not ship to the US even if I could find them on ebay. I cannot recall if the Mont uses the same AJP caliper and pad as the Sherco or not? I think it does? I'll gladly cover the costs, post is not too much on light things, and I think you have the paypal, makes it easy. Let me know if you can confirm they are the same AJP workings, and I will give a go! MC Quote Link to comment Share on other sites More sharing options...
the addict Posted October 22, 2008 Author Report Share Posted October 22, 2008 Mark, youve got mail Quote Link to comment Share on other sites More sharing options...
