richiec205 Posted October 19, 2008 Report Share Posted October 19, 2008 Hi have damaged a spoke in the front wheel so after ordering some new ones need to fit it. Only problem is there doesn't seem to be enough clerance to get the old one out / new one in at the center of the hub? Is it possible to change individual spokes without looseing all of them? Cheers Rich Quote Link to comment Share on other sites More sharing options...
jmck Posted October 19, 2008 Report Share Posted October 19, 2008 Hi have damaged a spoke in the front wheel so after ordering some new ones need to fit it. Only problem is there doesn't seem to be enough clerance to get the old one out / new one in at the center of the hub? Is it possible to change individual spokes without looseing all of them?Cheers Rich You won't have to loosen all of them, but you may have to remove the nipples from several spokes to allow enouph room to install the new one. Quote Link to comment Share on other sites More sharing options...
richiec205 Posted October 22, 2008 Author Report Share Posted October 22, 2008 You won't have to loosen all of them, but you may have to remove the nipples from several spokes to allow enouph room to install the new one. ok. won't this make the wheel go badly out of shape if you have to loosen quite a few of them? Quote Link to comment Share on other sites More sharing options...
