Miller Filter And Vm26 Mikuni On A T
michaelmoore
I discovered that the OD of the VM26 Mikuni bellmouth is just a bit less than the nominal (unstretched) ID of the Miller air filter's integral boot. I made a small adapter to press onto the bellmouth to increase the OD to the point that the boot has to be stretched to fit.
It wasn't a big project, but without it the airfilter wasn't staying attached, even when clamped. I thought it was worth mentioning in case someone else had to deal with this same combination of parts.
cheers,
Michael
Edited by MichaelMoore
