stork955 Posted October 20, 2008 Report Share Posted October 20, 2008 Gday all, does anyone have either or both of these laying around that they could measure the length of for me please? Thanks in advance, Cheers, Stork Quote Link to comment Share on other sites More sharing options...
jreilly Posted October 20, 2008 Report Share Posted October 20, 2008 Stork,Will see if I can measure for you and post later.JR Quote Link to comment Share on other sites More sharing options...
not ron Posted October 20, 2008 Report Share Posted October 20, 2008 My majesty has standard spacers, measured with the wheel in the frame the right (brake ) side is a simple steel spacer 49.3 mm long. The left (chain) side is more complicated as the spacer acts as a shield for the seal. The dimension is 10.6 mm from the inside of the swinging arm to the closest part of the aluminium hub to the swinging arm, this part is approx 50mm diameter and larger in diamter than the steel spacer. I hope this helps Quote Link to comment Share on other sites More sharing options...
stork955 Posted October 20, 2008 Author Report Share Posted October 20, 2008 Thanks for that, that should get me underway with the rear wheel at least. Cheers, Stork. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 21, 2008 Report Share Posted October 21, 2008 Stork I posted the spacer details including a photo on the Trials Australia website this afternoon. David Lahey Quote Link to comment Share on other sites More sharing options...
