phonomenon Posted October 20, 2008 Report Share Posted October 20, 2008 Hi guys, Was out on my beta when all of a sudden it just died on me, Tried starting it but nothing there! Its getting fuel but no spark. My first thought was the Coil. Does anyone know how i could test it?? Is there anything else i should be taking into consideration?? Ive checked all the connections and they seem ok and it recently had a new spark plug. Any thoughts or ideas would be apreiacted!! Cheers J Quote Link to comment Share on other sites More sharing options...
yamahaty250xox Posted October 20, 2008 Report Share Posted October 20, 2008 stator plate? seams common with betas of all ages now. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted October 20, 2008 Report Share Posted October 20, 2008 "Hi guys, Was out on my beta when all of a sudden it just died on me, Tried starting it but nothing there! Its getting fuel but no spark. My first thought was the Coil. Does anyone know how i could test it?? Is there anything else i should be taking into consideration?? Ive checked all the connections and they seem ok and it recently had a new spark plug. Any thoughts or ideas would be apreiacted!!" Dougie L, is that you - how did you get internet connection out on the moors above Richmond. Quote Link to comment Share on other sites More sharing options...
phonomenon Posted October 20, 2008 Author Report Share Posted October 20, 2008 No mate im not him, at least im not alone with this problem! J Quote Link to comment Share on other sites More sharing options...
dabomb Posted October 20, 2008 Report Share Posted October 20, 2008 If it will start after say an hour,it could be the stator.If it wont run at all,could be an electrical fault somewhere.You need to find out if the stator is ok.I dont know how this is done other than trying to start the bike later as mentioned above. Quote Link to comment Share on other sites More sharing options...
gaz Posted October 20, 2008 Report Share Posted October 20, 2008 Hi guys,Was out on my beta when all of a sudden it just died on me, Tried starting it but nothing there! Its getting fuel but no spark. My first thought was the Coil. Does anyone know how i could test it?? Is there anything else i should be taking into consideration?? Ive checked all the connections and they seem ok and it recently had a new spark plug. Any thoughts or ideas would be apreiacted!! talk about deja vu!!!!! same happened to me this weekend! Quote Link to comment Share on other sites More sharing options...
dan williams Posted October 21, 2008 Report Share Posted October 21, 2008 If your Beta has a lighting system on it you should read this. http://www.newenglandtrials.org/Beta_wiring.pdf Quote Link to comment Share on other sites More sharing options...
b40rt Posted October 21, 2008 Report Share Posted October 21, 2008 I would always try another new plug, just in case. Quote Link to comment Share on other sites More sharing options...
jeremyvi Posted October 21, 2008 Report Share Posted October 21, 2008 Hi, make sure you have a good connection between the spark and the spark plug, If the connection is ok, I would go for a stator plate. Be careful in buying a stator plate, make sure you are only buying the coils not the whole set. And avoid using the stop button in the future, it will save your stator. Quote Link to comment Share on other sites More sharing options...
phonomenon Posted October 22, 2008 Author Report Share Posted October 22, 2008 Still no answer, I have tested the stator and its giving out power to the regulator but still no spark! Today i fitted a new ignition coil hoping that it would solve it but still no sucess. Does anyone know what each colour on the stator is meant to do?? also could the regulator be causing a problem??? J Quote Link to comment Share on other sites More sharing options...
betarev3 Posted October 23, 2008 Report Share Posted October 23, 2008 I think you need to try a new CDI unit - I don't think the reg will be causing an ignition problem. Surely your dealer will let you try a CDI unit to see if this is at fault. Hoever, check all your earth connections just to be sure. Quote Link to comment Share on other sites More sharing options...
phonomenon Posted October 23, 2008 Author Report Share Posted October 23, 2008 CDI Unit, I asume you mean the ignition coil? If so i have bought a new one and fitted it and still no joy! This is fast becoming very frustrating! J Quote Link to comment Share on other sites More sharing options...
jeremyvi Posted October 23, 2008 Report Share Posted October 23, 2008 (edited) HI, You told us you had tested your stator plate, can you explain us how ? If a coil is cut off, nothing will work. Kr Edited October 23, 2008 by jeremyvi Quote Link to comment Share on other sites More sharing options...
phonomenon Posted October 23, 2008 Author Report Share Posted October 23, 2008 Hi Yeah i called Motoplat and he told me to get a multimetre and put the green and white on the leads, He said that i should have a reading of at least 400ohms which i do! So god knows whats going on. BUT since nothing makes sence i have decided to take the stator out to see with my very eyes that its ok! Will let you know how i get on J Quote Link to comment Share on other sites More sharing options...
