How Do You Change A Tyre?
sam12
On 22/02/2018 at 1:14 PM, jimmyl said:
DID rim and X light don't even need a beader  -just pop it on a blow it up.
Full tank of air and no valve 100% with a used tyre - might need two goes now and again with a brand new one.
Try and store the tyres with the bead turned out -helps get a mechanical seal with the rims so compressor can blow it up.
theres numerous ways to get tyres on, but as a simple device the beader cant be beaten. Any other method requires this or that, we have put a michelin on a rim with a foot pump using a beader.
Just watched the zip tie method on you tube .
if that’s the easy way I don’t want to see the hard way ?
as part of our 2 day trials training camp I do a tyre change and some basic maintenance .
its surprising what as well travelled riders we take fiir granted that the newcomer has no idea about .
remeber y&g having a tyre change comp in club night - it was a tubed  rear off the bike .
think glen scholey or maybe john Lampkin doing it in under 3 mins - security bolts and all!!
