m&s Posted October 29, 2008 Report Share Posted October 29, 2008 MartinM said: Blimey, you must be a Pro....how did you do 50+ trials between April and November when theres only been 23 weekends !!! Yes sorry about that it is actually 49 trials over 29 weekends often 2 per weekend & sometimes 3 on bankholidays Quote Link to comment Share on other sites More sharing options...
telecat Posted October 31, 2008 Report Share Posted October 31, 2008 M&S said: Yes sorry about that it is actually 49 trials over 29 weekends often 2 per weekend & sometimes 3 on bankholidays It's quite easy to do that amount of trials up here in the Yorkshire Centre. A typical weekend could see you doing a Saturday YG, Barnsley, Bradford, Craven or Spen Valley trial at 1 followed by a blast up to do a Wetherby or Ripon Trials at 5:30. Then Any of those clubs plus Centre's will be running on a Sunday Morning!!. Then on Bank Holidays Somebody will be running as well. Makes Practice at weekends a bit redundant. As for the X-blok's most experienced riders up here run them and yes I know exactly how they are constructed. The whole idea is that the plastic protects the metal. Did you enlarge the mounting holes on the carrier?? Quote Link to comment Share on other sites More sharing options...
the addict Posted November 1, 2008 Report Share Posted November 1, 2008 Quote Did you enlarge the mounting holes on the carrier?? Quote Link to comment Share on other sites More sharing options...
godzilla Posted November 2, 2008 Author Report Share Posted November 2, 2008 The mounting holes in the carrier were already the correct size. Still no word from the the shop i got it from so i doubt i will get a replacement , to be honest i am a little dissapointed. As for the plastic protecting the metal thats not going to happen if its not bonded together. It had no hard knocks it just came apart. Quote Link to comment Share on other sites More sharing options...
telecat Posted November 9, 2008 Report Share Posted November 9, 2008 godzilla said: The mounting holes in the carrier were already the correct size. Still no word from the the shop i got it from so i doubt i will get a replacement , to be honest i am a little disappointed. As for the plastic protecting the metal that's not going to happen if its not bonded together. It had no hard knocks it just came apart. The Guy who makes these is aware of this thread and has said that any "defective" X-blok should be replaced by the retailer. If you are having problems then get in touch with MRS who distribute them in the UK. The "defective" block will then be returned to him for inspection. As he said, and this is also my experience the X-blok does last longer and is much more resilient than the standard Chain tensioner block The design allows the minimum amount of metal used to be protected within the block. If you want to PM me with the retailers name, (don't post it due to forum rules), I'll pass the details to the maker. Quote Link to comment Share on other sites More sharing options...
godzilla Posted December 6, 2008 Author Report Share Posted December 6, 2008 I was refunded yesteday for the faulty x-bloc. maybe i will try one of these v-mar blocks next.. Quote Link to comment Share on other sites More sharing options...
