Cota 348 Piston Size
zulu
Hi zulu,
that's fine,
The P/N's are 5160.074 for a std piston kit, over sizes are +0.25mm and +0.50mm. I just measured the bore - luckily it is in good condition, it is 78.25mm diameter, the piston crown has a marking of 0.25 so I imagine then that the piston is a first oversize, of 0.25mm and the std bore would therefore be 78.00mm.
Bye, PeterB.
  • 1 month later...
