kozubs Posted November 5, 2008 Report Share Posted November 5, 2008 I have just recently gotten into trials. I picked up a 2002 scorpa sy 250. I'm having a difficult time getting used to the hydraulic clutch. I find it reacts extreemly fast with little to no feel. I've bled it (pain onto itself) but it still seems to be a light switch. I also find that the clutch is extreemly grabby when the bike is first started. I have to get hard on the brakes when I first put it into gear. My next step is to pull the clutch apart and inspect the basket but I wanted to see if anyone had some suggestions. Thanks all. Quote Link to comment Share on other sites More sharing options...
godzilla Posted November 5, 2008 Report Share Posted November 5, 2008 When was the cluch oil changed last? Quote Link to comment Share on other sites More sharing options...
dond Posted November 6, 2008 Report Share Posted November 6, 2008 I owned both a TYZ250 and a sy250 (same motor) With the TYZ, the clutch would stick if I let it sit for 2 weeks or more. I would have to break it loose by riding in 3rd gear holding in the clutch and twisting the throttle up and down. Then I put Silkolene light gear oil in it and it never did that again. So change your oil! Quote Link to comment Share on other sites More sharing options...
godzilla Posted November 6, 2008 Report Share Posted November 6, 2008 I use Putoline Off Road 4 stroke Oil, as recomended by nigel birkett. 650ml's Works a treat.. Quote Link to comment Share on other sites More sharing options...
