Ty250 Twinshock Electronic Ignition From Mono
mattylad
Yes you can but the firing position is different so you will have to elongate the slots in the mono backplate accordingly as it won't work in the same position as it does on the mono (can't remember which way this is) It will work using the TY twinshock flywheel.
Does it have to be a later mono system or will any one do the job. I picked up a 85 mono in bits for the forks and f wheel for the Majesty. I would fit the ignition as well if possible. :D
Edited by bo drinker
