Cota 200 Front Wheel
old bones
I've aquired an early cota 200 and would like some advice on the spacers in the front wheel between the fork legs .Either side of the front hub there are spacers which are obviously home made and dont seem to fit that well. Before I set the wheel up and do all the measuring I thought that it might be quicker to ask if anybody knew the proper length? Is there one each side or only one? Many thanks
OLD BONES
It may have been fitted with a different wheel to what came new on the bike. The "honda" pattern front wheel on 1980s Cotas is notorious for the spoke flange failing and people usually fit a different wheel to get around the problem (and because the same thing has already happened to all the bikes being used for spare parts). I've seen Honda CT110 wheels and earlier model Cota wheels used in Cota 200s and 349s.
