sir dabs alot Posted November 15, 2008 Report Share Posted November 15, 2008 I noticed when I took the side cover off the right side of my engine on my '06 Rev-3 that there was really nothing to prevent water entry than the cover. I put a small bead of grease around perimeter and reinstalled. Was that a bad idea? Quote Link to comment Share on other sites More sharing options...
fivemeister Posted November 15, 2008 Report Share Posted November 15, 2008 Not a bad idea but uneccessary as given the nature of the contents (movement - electrickery - heat - cold - condensation - water ingress) its pointless making a permanent seal and best to remove the cover after every ride anyway and spray with WD 40 / allow to dry. Some riders even drill the cover to allow constant moisture egress. Quote Link to comment Share on other sites More sharing options...
kinell Posted November 15, 2008 Report Share Posted November 15, 2008 Not a bad idea but uneccessary as given the nature of the contents (movement - electrickery - heat - cold - condensation - water ingress) its pointless making a permanent seal and best to remove the cover after every ride anyway and spray with WD 40 / allow to dry. Some riders even drill the cover to allow constant moisture egress. Excellent explanation, cue Eddie Lejuene to say you're wrong though... Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted November 16, 2008 Report Share Posted November 16, 2008 Excellent explanation, cue Eddie Lejuene to say you're wrong though... nah, if it works for you guys thats good, il do what works for me Quote Link to comment Share on other sites More sharing options...
fastandyc Posted November 22, 2008 Report Share Posted November 22, 2008 drill a hole tap it and thread a small bolt in that way you can drain it periodically Quote Link to comment Share on other sites More sharing options...
