Chain Length ?
gaff
Just changed my front sprocket from a 11 tooth (as i bought it) to a 10 tooth keeping the 42 on the rear (as standard on an 03 315), but the chain i took of was 102 link, as is the chain i have been advised to put on !
What chain do you use on a 10-42 set-up, with the wheel spindle set nearest to engine ?
Thankyou.
Gaff.
Easy way to shorten the chain:
Drape it over the rear sprocket, grid or file the pins flush with the plate and knock 'em out with a punch.
Make sure both ends of the chain end with 'inners' or 'male' ends, and when the chain is on the sprockets, there is only one tooth between the ends where the master link goes.
If your chain isn't too whipped, then you'll know how many links it should be for next time you buy one.
When I had a full-time shop, my answer to all the different chain lengths was to buy bulk length and cut every chain to fit. I never counted links.
