ham2 Posted November 20, 2008 Report Share Posted November 20, 2008 Hello men, Does anyone know if the open-cage needle-roller bearing that the clutch basket spins on is a sureflex part or is more widely available?My usual bearing supplier has drawn a blank. The inaccurate parts book has it down as a HK17-23-12 ( which I know it is not),if I remember rightly the prefix HK means the bearing is enclosed in a drawn cup ( which it certainly is not). Any replies gratefully received (unless they're abusive..Dabster ) Quote Link to comment Share on other sites More sharing options...
moleman Posted November 20, 2008 Report Share Posted November 20, 2008 I have to hand a SKF bag with a used one in, and it says 25x33x24 this is it on the "simply bearings" web site Quote Link to comment Share on other sites More sharing options...
ham2 Posted November 20, 2008 Author Report Share Posted November 20, 2008 Hi Moleman, As of 5 mins ago ,yes,it's apart now (my little compressor was struggling to work my rattle-gun). I've got a micrometer to measure the shaft dimension but no accurate way of measuring the bore that it fits into so... I'll go with your 98.345% . Thorough answer! Cheers, Wayne Quote Link to comment Share on other sites More sharing options...
chris morris Posted November 20, 2008 Report Share Posted November 20, 2008 you can get a hk1712 from INA, they are 17 bore 23 outside diameter and 12 wide as HERE, but they aren't an open cage Quote Link to comment Share on other sites More sharing options...
copemech Posted November 21, 2008 Report Share Posted November 21, 2008 Not an HK for sure, but how do you come to need one? And if you do, there is probably more! Quote Link to comment Share on other sites More sharing options...
ham2 Posted November 21, 2008 Author Report Share Posted November 21, 2008 Not an HK for sure, but how do you come to need one? And if you do, there is probably more! Good question,I don't think I need one but since I'm in there anyway.....The HK description is in the manual.... exactly my point,the manual (spares book) is wrong again ! Thanks for the replies fellas, Wayne Quote Link to comment Share on other sites More sharing options...
postmanpat Posted November 21, 2008 Report Share Posted November 21, 2008 The ref for an open cage type starts K........ Quote Link to comment Share on other sites More sharing options...
