dabomb Posted November 21, 2008 Report Share Posted November 21, 2008 Hi all,my kickstart on my 04 290 is playing up.It seems to "slip"for want of a better word.I`m guessing there is a spring loaded ratchet behind the casing which doesnt always engage with the kickstart lever.i`m thinking there is a spring broke or something?Has anybody else had this problem,and is it an easy fix? Cheers Quote Link to comment Share on other sites More sharing options...
copemech Posted November 22, 2008 Report Share Posted November 22, 2008 Hi all,my kickstart on my 04 290 is playing up.It seems to "slip"for want of a better word.I`m guessing there is a spring loaded ratchet behind the casing which doesnt always engage with the kickstart lever.i`m thinking there is a spring broke or something?Has anybody else had this problem,and is it an easy fix?Cheers They basically have a couple of sawtooth type gears that must engage as they cam in. On occasion they may not fully engage, depentant upon position and specially if you are too light on the foot, yet it just clashes sometimes. Doubt there is much wrong unless it is constant, then gears teeth could be rounded I suppose. Quote Link to comment Share on other sites More sharing options...
dabomb Posted November 22, 2008 Author Report Share Posted November 22, 2008 Thanks cope,would it be easy to check it out as it does it at least once every time i go out. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted November 22, 2008 Report Share Posted November 22, 2008 Thanks cope,would it be easy to check it out as it does it at least once every time i go out. You need to drain coolant, take the clutch case over off, take the clutch basket off then you can remove the gears and check them. Quote Link to comment Share on other sites More sharing options...
copemech Posted November 23, 2008 Report Share Posted November 23, 2008 Mark the clutch hub retainer nut so you may re-torque to proper position(rattlegun 3/8 drive preferred or you will need a clutch holder) and carefully note how the kick lever return spring is wound. That is all I recall as I have had beer since the last one I had apart! Oh, note shim washers and bearings on clutch and don't tear the case gasket, piece of cake! Quote Link to comment Share on other sites More sharing options...
