2000 290 Wheel Bearing Sizes
mick
I go for the freezer and heat method, as the fit is not as tight as older bikes.
I've just bought a set of bearings today for the Beta (they're 6004 2RS too).
Dabster, I'm guessing that the bearings go in the freezer so that they shrink and then when you heat up the wheel hub, it expands enough for the cold bearings to drop in easier.
Any tips on getting the old ones out?
Cheers
what the hell do you wanna put the wheel in fridge for!! guess u r joking!!, getting them out is quite tricky on some bikes as the internel spacer is a smaller diameter than the bearing. this means you cant slip a punch down and knock em oout. when faced with this i tend to get the mig welder out and build up a platform on the old bearings so i can punch them out.its quick and easy and harms nothin.(you need a welder though)
